Mopar Forums (/forums/)
-   -   Leaky Voltage Regulator (https://moparforums.com/forums/f10/leaky-voltage-regulator-25212/)
rocky321 Sep 22, 2023 07:02 PM
69 Charger 440 with the Mopar electronic ignition conversion. This setup came with the 4 prong ballast resistor. I recently noticed that the VR is dripping down the firewall. Still runs fine, but what gives with that?
Archer Sep 23, 2023 06:47 AM
rocky -
Might be some of the backing melting. Those things are pretty cheap, just replace it.
rocky321 Sep 23, 2023 07:19 AM
Originally Posted by Archer (Post 162043)
rocky -
Yea, I'm aware of that, but why is it melting?
Archer Sep 23, 2023 02:07 PM
rocky -
No idea, but the quality control of some parts these days can be ... questionable.
I'd just make sure it wasn't mounted near any heat source, on either side of the firewall.
d711van Feb 1, 2024 04:23 PM
It's a silicone used to keep the solidstate electronics from getting too hot. Their is also sand behind it. When you start losing stand, get a new one. What I do, which seems to solve the problem, is I put a few washes behind the unit, so air will flow behind it for cooling.
Skwerly Feb 2, 2024 10:09 AM
yeah, the washer method works well!
