lowering the fr. a bit?
was wanting to bring down the fr. of a 67 Belv.which way brings it down clockwise or counter.Is there a possibility I could brake something after these parts have been sitting for so long,of course I will lube it good
I think..... counter clockwise brings it down.
Make sure that you count your turns so you can bring both sides down evenly.
When you bring it down, the camber adjustment will be wrong as the bottom of the tires will stick out further than the top of the tires. It will look funny, the insides of the tires will wear quick and you will have to straighten this up at the new ride height.
Shouldn't break anything but, if you go too low.... you'll be bouncing off of the stops.
