Manifold Temps
Old Mar 12, 2011 | 01:34 PM
Slice's Avatar
Manifold Temps
Does anyone know how hot an intake on a 440 typically gets?
I've been going back and forth on how to protect an intake manifold that I recently polished. I've thought about powder coating or spraying with something like Eastwood Diamond clear coat, but all methods seem to dull the polish a bit.
I was thinking about just keeping it waxed with Carnuba wax. It supposedly melts at 180 degrees.
Old Mar 12, 2011 | 02:05 PM
Barfly's Avatar
Due to a resent experience I was reminded that "there is water in that thing" Meaning I would guess that all things being the way they should be you will have 180-200 degree water running through the intake. So I could only assume that the intake temp would be around there somewhere.
Joe.
Old Mar 12, 2011 | 02:31 PM
Slice's Avatar
Aha! thanks, I forgot to mention the crossover will be blocked.
Old Mar 12, 2011 | 04:08 PM
Well, on a 440 no coolant passes through the intake. Still, I would say it gets near 200 degrees.
Old Mar 12, 2011 | 10:19 PM
Barfly's Avatar
Really, no water goes through the intake on a 440.
Well I take it back then. Learn something new here
almost every time I log on.
Thanks
Joe.
Old Mar 13, 2011 | 05:29 PM
nope
the water is routed throught a housing in front of the manifold
98 SNAKE EATER
Jun 8, 2014 05:16 PM
Rosco83522
Jul 26, 2011 04:42 AM
deadkelly
Aug 30, 2009 07:24 PM
M1 Manifold
May 21, 2009 02:23 PM
Liu Kang
Jan 25, 2009 05:50 PM
