Manual Brakes
Old Dec 11, 2012 | 06:05 PM
dodgeman68's Avatar
Manual Brakes
Has anybody here upgraded their 68 B-body from manual front drum brakes to power front disc brakes? Not sure what kit to use that includes the power booster and master cylinder. Thanks
Old Dec 11, 2012 | 06:25 PM
fivepoint's Avatar
I did my 69 with a Stainless Steel Brake System kit. It came with everything needed rotors,calipers,lines,hardware, master cyl and booster. It will require you to use 15 inch wheels. Not sure if they still carry them but It was purchased at Eastwood Company. When they first offered them the price was good and it had free shipping. I have since added rear wheel disc that I put together myself with older GM rear calipers.
Old Dec 11, 2012 | 08:11 PM
dodgeman68's Avatar
Did the kit bolt right up? Manual brake cars and power brake cars had different backing plates bolted to the firewall behind the booster, just wondering if this was an issue
Old Dec 11, 2012 | 10:15 PM
The main difference was the reinforcement plate was used with out the power. I did the upgrade with factory parts on a 67 B body. I kept mine manual because of the performance cam & the lack of vacuum I actually liked it better that way
Old Jan 5, 2013 | 03:55 PM
bigblock's Avatar
Just forget the booster,you dont need it.Even with 4 wheel disc.
Old Jan 5, 2013 | 09:49 PM
theomahamoparguy's Avatar
Master Power Brakes is another very good source for MOPAR vehicles. ALSO, you could just use a collection of salvage yard parts and local auto parts suppliers to put something together and it would not cost that much. Other MOPAR vehicle's used similar or the same booster/master cylinders as the B bodies. One example; use some spindles from a Diplomat or a volare. The A body disc brakes from 1973 thru 1976 will also bolt right up to the B body. (I had a 66 belvedere with 74 Duster brakes on it)
Old Jan 12, 2013 | 04:46 PM
bigblock's Avatar
If you go with 4 wheel disc,make sure you have a dual disc master cyl.
Old Jan 12, 2013 | 05:15 PM
Use disk spindles from an A or B body that has disks. DO NOT use the Volare spindle it is taller.. The Volare rotor & brakes will fit fine Or the larger rotors from the dippy can be used... YOU DO NOT need rear disks
1968GTX
Jan 25, 2014 10:40 AM
HonkyCat
Nov 3, 2012 10:09 AM
Jwhis
Mar 19, 2012 04:09 PM
Stephen G. Rao
Feb 26, 2008 06:00 PM
dfrillan
Feb 20, 2008 07:17 AM
