manual transmissions ?
Old Jul 13, 2010 | 01:30 AM
timmie124's Avatar
later this week im going to be looking for a manual transmission to put into my 73 roadrunner and i wana be sure i get the right transmission to fit the engine.
i rebuilt a 63' 383
i was wondering what manual transmissions will fit the block
I'm probably gona go to pick your part and find one off a van with a big block engine but is there any thing i should know before i just take any old manual trans off a car
i want to do as little modding as possible
Old Jul 15, 2010 | 11:56 PM
jar84203's Avatar
Member
A-833 four speed manual. Check to make sure you get a big block bellhousing.
Old Jul 16, 2010 | 03:38 AM
timmie124's Avatar
is there anything else im going to need besides a clutch because im wanting to put this into a car that is currently automatic
Old Jul 16, 2010 | 10:43 AM
jar84203's Avatar
Member
Shifter, steering column if you don't want the auto shifter, but the vans won't work....make sure the yoke on the trans fits your driveshaft
Old Jul 16, 2010 | 03:52 PM
you'll probably need the 18 spline
not sure about the 23
Old Jul 16, 2010 | 06:22 PM
scotts74birds's Avatar
Will his motors crank be drilled for a pilot bearing? You WILL need a pilot bearing/bushing for a manual.
Old Jul 16, 2010 | 08:18 PM
1966sportfury's Avatar
A.K.A Bob Dodge
need the right crank/or drill the crank, 18 or 23 will work,, BB bell housing clutch pedal, Zbar linkage
and im sure im missing somthing
bb
Old Jul 16, 2010 | 11:48 PM
johnthegoalie's Avatar
thinkin with me dipstick
drilled or not, the newer mopar roller pilot bearing is the way to go. if the crank isn't pilot drilled, you use the roller and cut like 5/8" or so off the input shaft
Old Jul 17, 2010 | 01:09 PM
6T9Bee's Avatar
Junior Member
you can try Brewers for 4 speed parts if you're having a hard time locating them locally.
Old Jul 17, 2010 | 09:50 PM
timmie124's Avatar
so i need to modify the crank shaft in order to put in the manual trans?
because orignally i thought all you had to do was remove the flex plate and bolt on a flywheel then clutch and then the transmissions
Old Jul 17, 2010 | 11:53 PM
you need a pilot bushing - most cranks are drilled and machined the correct size, some are just drilled and not machined and a few have nothing. mopar has a roller bearing that fits in the larger machined crank register. if yours isn't drilled at all you will have to saw a little bit off the input shaft
Old Jul 18, 2010 | 12:28 AM
timmie124's Avatar
ok so i started looking around for the bearing for the crank shaft online and im unable to find one for the engine, is there another engine that uses the same crank or am i gonna need to special order a bearing or bushing
Old Jul 19, 2010 | 09:09 PM
67gtxclone's Avatar
Make sure the clutch you buy matches the number of splines on the trans you buy.
Old Jul 24, 2010 | 05:58 AM
adamst56's Avatar
I recommend (as above) looking at the Brewer's site or calling them. Nobody knows more or has more parts. You can get either a 23 or 18 spline. You need a big block bellhousing but it needs to match the pilot bearing diameter of the 23 or 18 spline trans. You will need a flywheel. Obviously your clutch will need to match the 18 or 23 spline shaft. You will need a trans with the right tailshaft (long tail shaft) with the correct shifter pad (front for B-body) for your car. You will need a 4spd floor hump. Brewers has everything you need.
http://www.brewersperformance.com/default.htm
The slant six forum also has a good article on A833's
http://www.slantsix.org/articles/4-s...fourspeed1.htm
HonkyCat
Nov 3, 2012 10:09 AM
gearheadmike
Aug 21, 2011 08:33 PM
blue 68 gts
Oct 20, 2008 07:21 AM
KATMAN
Jul 16, 2008 07:54 PM
ucfierocharger
Nov 20, 2007 07:16 AM
