paint code for Limelight/Sublime green
Now correct me if I'm wrong, but I take it both are the same color?
Going over some paperwork I found my 69 RR was listed F/S as Sublime (which is incorrect for the year anyways) Just looking to mix up some touch up paint. Anyone happen to know the code(s)? |
1969 Limelight is EJ5. The first letter is the year. The code J5 is used every year. E is 1969, F is 1970, G is 1971.
I just told my paint guy J5 and it's perfect. For a touch up you may want to order some paint chips. |
Hmm, I was under the impression that Rally and Ivy were the only greens available in 69 :confused:
*sent from my android powered string cup* |
The 1969 "Limelight" is a much darker green. After looking it up, It's code is different than I listed too.?? Shows as F5.....
http://www.cowtownmopars.com/color.html |
OK, so which greens were specifically available on the 69 RR's only?
Also, is the 70 Limelight and Sublime the same code? (I don't see Sublime anywhere) |
| All times are GMT -7. The time now is 12:34 AM. |
