Removing door panel?
Old Apr 4, 2013 | 04:34 PM
98 SNAKE EATER's Avatar
Question Removing door panel?
Anyone have a photo of the backside of a B-Body door panel? (preferably RR if it makes a difference)
I need to remove mine in order to install a mirror and just want to get an idea where all the fasteners are before I break sumthin
Old Apr 4, 2013 | 07:05 PM
No biggie, take the armrest and door handle off. Start pulling gently at the bottom until one retainer pops out. Then work your way around to the top. Get you hand as close as you can to each retainer when pulling and you won't rip anything. You will need to unscrew your lock button then lift the door panel up and off the door.
Old Apr 4, 2013 | 10:13 PM
jacilynn_s's Avatar
Pretty much what he said. Allen screw in window crank that points forward with window all the way up. I prefer to use a putty knife myself when pulling door panels.
Old Apr 5, 2013 | 06:23 AM
So there's no retaining clip for the crank, just an Allen screw?
Also, I have a set of these that I use on all doors....
They usually work great, but it always helps to know exactly where all the clips are.
Old Apr 5, 2013 | 08:28 AM
Moparod's Avatar
It's about as complicated as watching paint dry. Just slip your widget tool behind the panel and slide it along until it hits a clip. The 68-70 B-Bodies don't have clips at the top of the main door panel, it slips underneath the chrome strips and is clipped along the front, back and bottom. Been a long time since I had one off but I want to say it's something like 6-8 along the bottom and may be 4 along the edges.
Old Apr 5, 2013 | 11:54 AM
jacilynn_s's Avatar
Top two along each edge are not usually used. There is holes for them and you can put clips but originally they weren't.
If you think the door panel is fun try the windbarrier behind it That one slips into the groove cut in the door at the bottom with 1 in wide hockey tape over it.
Chrysler window cranks are easy because of the allen screw. Remove screw and pull off no clips.
I should warn you half the time the cardboard of the panel is warped or water damaged and or disintegrated. Upholstery shops usually redo them with a press board that is stiffer. Any material not glued to the board can be reglued with contact cement. The spray stuff just doesnt hold.
Old Apr 5, 2013 | 06:46 PM
Yeah, this is actually what scares me the most about these old panels
Before pulling any door panels, I always do a search for photos showing where all the main clips are to avoid tearing it up
Old Apr 7, 2013 | 08:09 PM
I figured I'd update with pix
No busted clips, but one was missing
Old Apr 10, 2013 | 12:10 AM
70redbee's Avatar
Get you some fender covers and blankets on that badboy to protect the paint.
Old Apr 10, 2013 | 02:34 PM
jacilynn_s's Avatar
Your missing the plastic inside the door panel. Hope you like wind coming through the doors. Wow you even have the uncommon clips in the door panel cools!
Old Apr 10, 2013 | 02:42 PM
pro-tech's Avatar
what color is that??? it looks alot like the color on my duster.
Old Apr 10, 2013 | 03:44 PM
Got one
You mean the ones with the white washers?
Either Sublime or Limelite
As far as I know, it's incorrect for the year
Old Apr 10, 2013 | 04:04 PM
jacilynn_s's Avatar
nope usually most door panels only had like 2 of those on the outer edge the rest were spring type clips. Those are better and do less damage to the panels.
Old Apr 10, 2013 | 04:14 PM
I'm gunna pull the driver's side tomorrow just to tape it cause the bottom edge is hanging loose
Old Apr 11, 2013 | 04:00 PM
OK, the driver's side didn't look as nice as the passenger side
A few missing clips and a chunk had separated, so I broke out the Gorilla tape and spread out the remaining clips evenly.
Old Apr 11, 2013 | 04:54 PM
pro-tech's Avatar
Nope not the same color. Mine is curious yellow/ citron yella. it looks green under the metal halide lights in my garage/man cave. Your RR is very sweet looking.
Old Apr 11, 2013 | 06:12 PM
Gorts 5th's Avatar
Talking
go get yourself some heavy mill plastic and gorilla tape it to the door then install your panel.
icecat66
Dec 7, 2013 08:09 AM
gsbrock12
Sep 1, 2013 06:43 PM
69440GTX
Aug 31, 2013 10:58 PM
kildump
Jul 15, 2013 02:54 PM
BuckNeccid
Feb 26, 2009 11:20 PM
