Mopar Forums (/forums/)
-   -   Stewart Warner 970 help (https://moparforums.com/forums/f10/stewart-warner-970-help-15200/)
Brian Kotula Jun 29, 2013 07:39 PM
I got a vintage Stewart Warner 970 tach with a 990 sending unit. I want to install this on a 69 Roadrunner with a new 426 crate gen 3 Hemi motor and the M+H engine harness, the one with the orange distributor box and black electronic voltage regulator with duel field alternator. Any Idea's on how to wire? Do I pick up the red wire off the ignition switch? How about what side of coil to use? The yellow wire before the ballest resistor or after?
moe7404 Jun 30, 2013 11:34 AM
i have am old Stewart Warner tach. it might be the same as yours. i bought mine in 1967. but it is broke. and in pieces. it is a 0-6,000 RPM. not even sure i know where it is. if i can find it you can have it.
Brian Kotula Jul 13, 2013 10:19 PM
RE:
Thanks for the offer, but I got a tach and Inow got a set of instructions so I'm good to go. Thanks sincerely Brian
440roadrunner Jul 14, 2013 07:16 AM
The problem, here, is you seem to have the destructions and I don't. I don't remember how these old Suns were wired.
Most tachs need a trigger off the points. There are a few that were actually wired in series with the positive coil feed.
If your ignition has a 4 terminal ballast, you need to determine which (two) terminals are the ignition feed. This will be the end of the ballast with the two terminals jumpered together.
If you have a two terminal ballast, the ignition feed is easy. Just unhook one end, turn on the key, and use a test lamp to see which lead is "hot."
Normally, a tach needs a trigger off the points, and in the case of a Mopar ECU, this is the coil NEG terminal.
