Mopar Forums (/forums/)
-   -   Suspension colors for stock 1968 Coronet R/T Convertible? (https://moparforums.com/forums/f10/suspension-colors-stock-1968-coronet-r-t-convertible-1515/)
Hotwheels Sep 17, 2008 06:56 AM
I need to know the colors for the whole suspension,brakes K-member and all the little parts that goe with it. Can anyone steer me in the right direction to find this info please?
Doc Sep 17, 2008 09:03 AM
??????...... but a suggestion. Go into eBay and plug-in your car details. Then contact the seller of a restored vehicle and ask them for a pic.
Hotwheels Sep 17, 2008 11:55 AM
Thank you Sir. Good idea
Commando Sep 17, 2008 12:13 PM
I have been noticing that there a lot more underbody pics on eBay than I remember, so you may be able to get lucky.
richinny Sep 17, 2008 12:43 PM
i seem to only recall seeing black but i'm not sure what shade.
rr69half6bbl Sep 17, 2008 10:18 PM
they used a satin finich for the k-frame, drag link, upper and lower control arms, and then the spindle arms.the idler arm, pitman arm, &tie rod ends were natural finish gray. I know that its nice to do the correct finish, but ill tell you what wappens, after you do that, if you drive the car at all, within weeks the nat. fin. parts are red w/ rust. if you dont drive the car, then by the end of the summer they`re red w/ rust from getting the moisture from the garage floor. The gray paint that eastwoods sells for the steeringgear and other parts, starts to wear off after 1 season. you have to recoat it . When I do the front ends on cars, I just get the chasis black paint from napa, and have the blast shop clean them up then coat the crap out of them , it all gets blck regardless what it is, then the front end looks great all the time for as long as youll own the car. rust doesnt do anything for the looks of the car, specially when people se how nise the car is then they look under neath and go YUCK!! youe call, or you can get it all powder coated, ita alittle more but man does it look nice.
