tire size
hi at mopar world!
i am from italy an d i amnew in this forum:) in my Roadrunner '68 i want to change the original tire f70 14 . i have in garage a set of cragar ss with Rim Diameter (in): 15 in. Rim Width (in): 8.00 in cod .n CRR-61817 , well what size do you suggest me with this whhels without changing anyabout the fender or rear suspension? i am thinking about 275/60-15 or 275/50-15....295 it is impossible...what do you think? and the fornt tires? 245 it will be good? thanks for your replay enjoy with your mopar |
Tire sizes
It all depends on two factures.
1. Do you want a stock look? If so use 205/75/15 or 205/70/15 for the front and the rear/ 2. Or would you like the 1960-70's muscle car look? On my 1971 Charger R/T, I have 235/60/15 on the front and 445/60/15 on the rear. The one problem you will find putting the large size rear tires on the rear is space. you will have to raise the rear-end up to get the clearance, (i.e. air shocks with shock lift extentions or air shocks with spring shackles, or cut and re-tub the rear fender wells. What I used was the first one so that would be able to return my Charger to stock height when I needed to. Best of luck. :D |
