Upper control arm, ball joint and spindle
I purchased upper control arms/ball joints and spindles for a disc brake conversion to my 66 Coronet 500 convertible. Is there a washer that goes between the spindle and the upper ball joint? The balls joints included a typical and a thick washer, but I'm not sure where they go. The only washer I am aware of is between the castle nut and the spindle.
And finally...anyone in the Detroit area know a good alignment guy? Any thoughts are appreciated. Thanks! |
One between castle nut and spindle
One between Outer wheel bearing and castle nut... But with the conversion... You might have 2 washers left over... :) |
Much appreciated!
