Mopar Forums (/forums/)
-   -   What is correct TorqueFlite transmission fluid for 64 Ply Belvedere 318 (https://moparforums.com/forums/f10/what-correct-torqueflite-transmission-fluid-64-ply-belvedere-318-a-17928/)
Dad-Par Oct 12, 2014 09:21 AM
Just purchased this vehicle (all orig daily driver) and want to be sure I'm going to use correct fluid. Always remember 'Type A'. Is current replacement Dexron/Mercon (progressive upgrade from Dexron, Dex II, III, addition of Mercon etc) correct for today.
pro-tech Oct 12, 2014 02:26 PM
Yes, Dextron III is what they call for now it has better lubricating factors then the old fluid... Bill
Rooty Oct 12, 2014 04:29 PM
I just changed my fluid in my 727 and Dex/Merc was recommended by service guy
at Chrysler dealership. Evidently it foams less, lubricates the moving parts better
and provides firmer shifts to keep the bands from glazing prematurely. Really, I
don't think conventional fluids make much difference but to be on the safe side,
ask a tranny place what they recommend.
TVLynn Oct 12, 2014 09:09 PM
There is NO Dextron III, Replacement ATF+4
RacerHog Oct 13, 2014 08:59 AM
Transmission Fluid Info
Just an FYI.... Transmission Fluid info Sheet....
http://www.carquestprofessionals.com...%206.10.13.pdf
moe7404 Oct 13, 2014 09:07 AM
in the late 60s early 70s we did use type-F in torqueflites. but today i would only use ATF+4. minor history note: i was working a Case MFG in Wichita KS and engineering came out and said that type F could be used in the hydraulic systems. worked good in cold weather. my dad bought a Case garden tractor in 1975, 446 , 2 cyl engine. hyd system was sluggish when plowing snow. switch to type F fixed the trouble. its still in the 446. but today i think i would run AFT+4
Dad-Par Oct 13, 2014 12:46 PM
Correct Trans Fluid
Thanks to all. Have bottle of Castrol DexonIII/Mercon in front of me as I type. However just an FYI, was on OReilly Auto website under Fluids
&Chemicals > Transmission > found 'Type A' trans fluid - 'Pure Guard' brand (?) avail as a non-stock item avail in 24 hr item. Go figure. Not sure I m ready to jump at that.
RacerHog Oct 13, 2014 04:24 PM
Moe... you should have used AW68 in that system.. Not Kansas crude oil...lol
RacerHog Oct 13, 2014 04:27 PM
Some of that I just don't trust.... Pro Line oil was one that said it covered everything, "I just slowly put it back on the shelf and backed away" I to went with the Castrol....lol
pro-tech Oct 13, 2014 07:32 PM
Wow good to know I had better pull all the Dextron III or if you prefer Dex/Merc. off the shelves at the AutoZone store I manage.. I don't want to be selling something that is a figment of my imagination...:laugh:...Bill
RacerHog Oct 14, 2014 06:34 AM
I think it's fragment Bill......lol
pro-tech Oct 14, 2014 03:06 PM
No Bob it is figment...:slap: It means Something merely imagined...:poke:...Bill:laugh:
moe7404 Oct 14, 2014 05:24 PM
its just an out dated history NOTE. i dont under stand why EVERY MFG that makes a NEW trans need a NEW fluid. the old one seamed to work fine.
pro-tech Oct 15, 2014 05:46 AM
X10 cashcashcashThat's why and it sucks...And the smell gets worse too....Bill
RacerHog Oct 15, 2014 06:20 AM
Money is the key.... Keeping us guessing... :)
