1965 880 Custom (Parts and Tips)
Old Jan 7, 2010 | 12:57 PM
Kinger1421's Avatar
Junior Member
Exclamation 1965 880 Custom (Parts and Tips)
So i have had this car for a couple years now and havent got much done with it. One major thing holding me back is that i cant find a radiator for it without getting a custom one done ($$$$$$). And for whatever reason it wont start anymore. Just getting a click somewhere on the driverside of the fire wall. Battery, Starter, Starter Relay are all good. Wireing looks to be fine too.
Old Jan 7, 2010 | 01:04 PM
rexus31's Avatar
It sounds like the battery is dead. How many volts is the battery holding?
Old Jan 8, 2010 | 01:47 AM
Kinger1421's Avatar
Junior Member
Nope the battery is fine. I have an optima red top and a yellow top. The yellow was in there and i swapped it out for the red in my other truck. the yellow started fine in my truck once i installed it. Although the red brought me that click, the yellow brought me the same click but i would have to pull the terminals to get it again. where as with the red i get it every time
Old Jan 8, 2010 | 08:06 AM
rexus31's Avatar
It could be the Voltage Regulator.
Old Jan 9, 2010 | 12:14 AM
Kinger1421's Avatar
Junior Member
Got one of em on order along with a few other things that probably should be replaced anyway.
Old Jan 17, 2010 | 01:23 PM
Kinger1421's Avatar
Junior Member
Well the Voltage Regulator was a failed effort. Unless this starter switch im about to install works im at a loss and dont know what to do next.
Old Jan 17, 2010 | 02:08 PM
scotts74birds's Avatar
I dont want to be a smart-***, but CAN the engine turn? My camero locked-up from sitting outside for 3 years.
Old Jan 17, 2010 | 02:41 PM
sgnrulz's Avatar
Do you have power to your fuse box?
If you run current across starter relay what happens?
Check all your leads and grounds.
Old Jan 23, 2010 | 04:59 PM
Kinger1421's Avatar
Junior Member
What the hell is going on?
Ok lemme fill you in. The voltage regulator didnt do anything but make it look a little better under the hood. one less rusty part. I changed the ignition switch and it started turning over. didnt start because by the time it had fuel threw the filter a wire started melting and smoking. i fixed the wire but now smoke is coming from under the dash by the new ignition switch. I pulled it to check it out but not sure what to do now. DAMNIT!!!!!
highroller4321
Jun 30, 2010 08:01 PM
sledgeman
May 12, 2010 02:03 PM
65Custom880
Jan 25, 2010 07:32 PM
Kinger1421
Mar 3, 2009 10:05 AM
Mopar Guy in Delaware
Apr 3, 2008 06:30 PM
