Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   1966 Fury III engine (https://moparforums.com/forums/f11/1966-fury-iii-engine-10955/)
Arbiter343GS Oct 27, 2011 12:07 AM
I have a 1966 Plymouth Fury III and The VIN says I have a 318 "LA" engine, but I dont have the same(or at least I think) valve covers as an LA, It looks like I have a Poly 318 "A" engine(there are two bolts ib the middle of the valve cover). Is this something significant, or could someone have done an engine swap and changed it from an "LA" to an "A"? And also where is (if there is) a casting number or some sort of number that tells me what the info on the engine?
Arbiter343GS Oct 27, 2011 12:16 AM
I will also post a pic of the engine when I wake up in the morning.
Arbiter343GS Oct 27, 2011 11:14 AM
2 Attachment(s)
Here is a pic of the engine and the valve cover
TVLynn Oct 27, 2011 07:03 PM
66 was the last year for the poly 318.I would suspect they used them until the supply ran out. Then switched to the new LA318
Arbiter343GS Oct 27, 2011 09:30 PM
I had a feeling it was something like that.
thohill Oct 30, 2011 06:57 AM
yeah absolutely. check which month the car was produced.
Arbiter343GS Oct 30, 2011 05:22 PM
February
66coronet440 Oct 30, 2011 05:46 PM
its a poly "a" motor 100% i have the same in my 66 dodge coronet. Also they made the 318 poly "a" motor until 1967 on Canadian applications. Parts are very hard to find, definitely look into swapping the 318 for a bigger motor, because like i said parts are pretty scarce and/or cost a fortune.
________________________
1966 Coronet 440 318 poly
bboogieart Nov 11, 2011 02:12 PM
Maybe just a later 318. a lot less head ache.
