Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   1966 Monaco Electrical (https://moparforums.com/forums/f11/1966-monaco-electrical-3259/)
Monaco383 Jun 9, 2009 10:28 PM
Hi everyone I have a 1966 Monaco with a 383 2bbl. i got it off my cousin and they screwed up the electrical they did something stupid that ended up melting the fuse box so i replaced it just like i took it apart. but now one brake light work driver side the blinkers are blinking the diagonal from each other and the dash lights don't work. had this guy look at it and he got the brake lights fixed but then after like two weeks it messes up again took back same thing fixed two weeks later broke. anyone have any idea i want to get it fixed thanks.
Polaradude Jun 10, 2009 03:07 AM
Welcome to the forums, how's your level of electrical knowledge ? It sounds like you have a lot of tracing to do. Maybe it's only a couple of bad connections though. We'll help if we can.
Monaco383 Jun 10, 2009 10:09 AM
thanks for the welcome glad i found this place. i have recently gone though schooling for cars which would be UTI one of the top in my class and have advanced training in volkswagen. i know a decent amount but no one knows everything. i figured that i'm going to need to do some tracing but i don't know where to start and i can't find a wiring diagram for this car. one of my teachers said that the turn signal switch is where a lot of the wires for the brake lights are and i'm thinking that when my cousin melted the fuse box that it might have got melted to.
Polaradude Jun 10, 2009 10:41 AM
1 Attachment(s)
I hope you can see this, if not let me know.
Monaco383 Jun 10, 2009 10:49 AM
Sorry can't really make it out
Polaradude Jun 10, 2009 11:00 AM
Can you cut/paste it somewhere else and blow it up, or I can send it to an e-mail addy. Let me know.
scotts74birds Jun 10, 2009 11:13 AM
http://www.mymopar.com/downloads/196...araMonacoA.JPG http://www.mymopar.com/downloads/196...araMonacoB.JPG There ya go, just easier to copy the link location and paste it from my "secret" site.. I'm a car guy and an electrician by trade so I might be able to help. Good luck.
Monaco383 Jun 10, 2009 11:40 AM
You guys rock i got the pictures from your secret site printed them now any ideas where i should start.
scotts74birds Jun 10, 2009 12:12 PM
Start by very accuratley describing what was done and what works, what doesnt and whats acting weird. Guages, ashtray light, inst. lights, domes?
Monaco383 Jun 10, 2009 12:37 PM
well my cousin did something not sure but it involved him connecting the headlights to the battery directly which ended up melting the fuse box. My dad replaced the fuse box. the problem is my driver side brake light works but the passenger side does not. the blinkers goes left front and right rear and right front and left rear. one back up light does not work but i think thats a bad bulb. the dash lights use to work but now don't same with the transmission light indicator in the console. sometimes the headlights won't work but if you play with the high beam switch they will come on. and the horn don't work. but the park lights work fine.I think thats it any ideas. if any more questions i ll try to answer them. but i'm thinking its the Direction signal switch got fired too.
scotts74birds Jun 10, 2009 12:42 PM
K, start with the turn sigs. Say you put the LEFT blinker on, does it go left front and right rear, or right front and left rear?
67 GTX Jun 10, 2009 03:25 PM
Monaco383 Jun 10, 2009 05:16 PM
sorry guys my battery is dead right now got to wait a couple of days to get the money for new one. been trying all day to get the battery charged and it won't take it has two dead cells. But if there is anything i can do now until i get the new battery or should i just wait some more.
Polaradude Jun 11, 2009 03:02 AM
Well ya could leave the batt in the car on a trickle charge and do testing.
Monaco383 Jun 11, 2009 12:17 PM
it won't blow up the battery?
Polaradude Jun 11, 2009 04:48 PM
It shouldn't hurt anything on a trickle, do your checks and then un hook it.
Safety first though, if the sides of the batt are getting warm on a trickle charge which it shouldn't, stop. Keep us posted.
Monaco383 Jun 11, 2009 06:02 PM
Ok You got I'll give it a try it shouldn't take long any ways. thanks you guys rock.
Monaco383 Jun 11, 2009 08:21 PM
ok guys here the findings blinker switch in left: rear blinks front does not. Blinker switch in right position: both blink. Parks on: all lights light. Brake pedal pushed: driver side only, all bulbs in passenger side are good. Battery can't put enough power for headlights. Any ideas? thanks
richinny Jun 12, 2009 04:09 AM
the flasher may not work if the battery voltage is low or it may flash one suide and not the other.
check to see if power is getting to that front left socket and also check the ground there.
if you have a left rear brake light, trace that wire over to the right side. your problem is between the left tail light to the right
bulb. i forget if the right lamp piggybacks off the left side or slits at the trunk connector so you might have to check there too.
Monaco383 Jun 12, 2009 11:41 AM
Found the problem it was the directional turn switch the contacts aren't making connection for the passenger brake light. I jumped it and pushed the brake and it worked!!! But now I need a new directional turn switch and Autozone napa don't have it any ideas where to get one? Thanks
Polara_68 Jun 12, 2009 07:25 PM
The Wells brand of auto parts has a listing for a
"Turn Signal Switch Repair Kit" for your car..
(Part # TSR105)
http://www.e-webcatalog.com/wells/ecatalog.aspx
In my area, Carquest and Autozone carry Wells brand parts..
If you can't find 'em, call their Support Hotline: 1-800-558-9770.
When prompted, press: 1 for Customer Service
and ask 'em for a retailer near you..
hope that helps ya
good luck
scotts74birds Jun 12, 2009 07:31 PM
Way to go 68!
67 GTX Jun 13, 2009 02:30 PM
first place to look would be ebay
Monaco383 Jun 15, 2009 08:01 PM
Alright i found one at http://www.arizonaparts.com for $70. its a reproduction. cool guy if you guys need anything give him a call. has decent prices i also got a service Manual for $27.00 its from 1966 and its brand new. year one wanted $169 for the same turn signal switch. tomorrow I'm going install it I'll update on how it works out. thanks for all your help.
Monaco383 Jun 16, 2009 11:07 PM
Ok all the brake lights come on sort of the driver side outer one is bright and the rest or them are super dull. if you hold the brake on for a while the bulbs get a little brighter.
Polaradude Jun 17, 2009 03:02 AM
Sounds like a bad ground or connection, go from the bright one to the other side and look for a bad connection etc. Gettin there.:D
scotts74birds Jun 17, 2009 08:54 AM
Po-daddy is right . Thats the #1 clue to a bad ground.
Polaradude Jun 17, 2009 01:22 PM
Yo dat home slice...lmfao:D:D
67 GTX Jun 17, 2009 02:00 PM
polara should be in a straight jacket
lol
scotts74birds Jun 17, 2009 02:02 PM
Grrrrrr, bondage! I'm not here to judge you folks!
