Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   1975 PLYMOUTH GRAN FURY STARTING ISSUE (https://moparforums.com/forums/f11/1975-plymouth-gran-fury-starting-issue-24553/)
conscriptbb Apr 29, 2022 04:44 PM
https://cimg7.ibsrv.net/gimg/moparfo...d62e90f53d.jpg
https://cimg5.ibsrv.net/gimg/moparfo...2c4b43bf69.jpg
I want to start by saying I have little knowledge of ignition or electrical systems on cars. I bought this car to be my family car and to enjoy on occasion. Unfortunately I cannot get the car to crank/spin. I am getting power but this little device mounted on the firewall clicks when I turn the key. The letters are worn from age and I have no idea what this is. Any help would would be greatly appreciated.
WillyPickton Apr 30, 2022 01:43 AM
That there is your starting relay...Lookee here:
https://www.ebay.com/itm/22495472657...waApcwEALw_wcB
conscriptbb Apr 30, 2022 04:45 AM
That looks pretty close, but there are sockets on the bottom of it that are different.
Archer Apr 30, 2022 05:32 AM
c -
Yes, that's a starter relay, and sure it could be bad, but you might want to check your battery first, if you haven't already done so.
conscriptbb Apr 30, 2022 05:54 AM
That is a good point, it might be weak. I'm going to go try to get the part now, I'll have them check the battery too. If nothing works, I'll lift it and remove the starter
RacerHog Apr 30, 2022 09:46 AM
I dont believe that is the start replay !!!!!!
That looks like more like a A/C Blower Blower Motor Relay....
I would check to see if your getting power to the Starter Relay? After that I would check the Neutral Safety Switch and also the Seat belt start lockout ....
Also>>>>>
if you want to see if it will crank? on the starter relay>>>> Use a screwdriver and jump the large battery cable post to the little small screwed in wire terminal and it should spin over... then you will at least know that much is good....
conscriptbb Apr 30, 2022 10:25 AM
Thanks brother. I'll give it a shot here shortly
WillyPickton Apr 30, 2022 12:08 PM
You could might be right there, Bob. Cheap enough I guess...But would the AC blower relay stop the car from starting?
https://www.classicindustries.com/pr...s/3747174.html
RacerHog Apr 30, 2022 01:15 PM
no...
