65 4door polara maxwedge from factory???
i need some help i have a 65 polara at mt back door for 200 factory original and 100% complete that looks like it has a maxwedge did they come with them in 4doors if so i need to know so i can jump on it
NOPE ! And what makes you think it's a Max ?
the headers are turned up in the engine bay I thought only max wedge motors had them turned up
So far as I know none of the "max wedge" heads had exhaust head crossovers in the heads--so that should be easy to spot.
What do you mean "headers?" Factory max wedges so far as I know came with cast manifolds, but you are right--the cast max wedge manifolds were huge, and "arched" the lower HP wedges had "straight" cast manifolds. |
