| Oyeller |
Mar 29, 2020 09:32 AM |
67 Chrysler Newport power steering pump for 383 engine
Hi ! New here to the forum. My situation is that the TRW pump is leaking and apparently can't be rebuilt due parts availability ? It was suggested to switch to a Saginaw P model . I am fine with that but will need to find a different bracket for it. Who out there has a 383 with a Saginaw power steering pump? I would be interested in seeing the bracket and pump installed. My current bracket is a strange clamshell design and is difficult to adjust the tension and the pulley is at a slight angle which causes belt wear and black power residue .
tnx
