Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   '68 fury iii disc conversion (https://moparforums.com/forums/f11/68-fury-iii-disc-conversion-19692/)
Born_Again Sep 11, 2016 08:20 PM
I'm trying to convert my front brakes from drums to discs. I've found kits all over the internet for A,B, and E body styles but the only one I saw for C body was just the caliper and rotor. I know my body style is very similar to a Dodge Roadrunner and a Roadrunner is B body so I wasn't sure if a B body conversion kit would fit or not, and I'm trying to do my research before I spend that kind of money on the wrong kit.
lmnlmno May 31, 2017 11:32 AM
I used the SSBC A154 front disc conversion. I got it from Summit which was a few hundred less than SSBC was directly selling it for. The kit was well put together and included just about everything. The only thing aside from the kit that I needed was a tube bender and some adapters for the brake line provided. I just checked Summit to see if they still have it and it looks like it comes sans booster now. Might try calling them after you give it a look-see and see if you can find a kit with booster if that's what you're into.
Born_Again Jun 1, 2017 04:07 PM
​​​thank you for the information. I looked at the kit and it looks like it's exactly what I need. What vehicle did you use it for??
lmnlmno Jun 3, 2017 02:04 PM
I used it on a 65 Fury III.
