68 newport Sub frame connectors
Old 08-21-2015 | 09:37 AM
70newport's Avatar
Hey guys,
My 68 newport 4 door is really squeeky when driving. I was wondering if you guys think sub frame connectors would help eliminate some of these noises as well as if any of you have built any previously. I can not find any for purchase.
Thanks,
Gary
Old 08-21-2015 | 10:27 AM
Archer's Avatar
Gary -
Couldn't hurt, but it's probably not your biggest problem. Given the age of your car, the odds are really good, a lot of your suspension is shot - even if it looks OK or even good. Metal fatigues and stretches and rubber bushings rot. Unfortunately, even a good inspection may not reveal the real culprits until you start taking things apart.
I just went through a full suspension overhaul/upgrade (and yes, I added subframe connectors), and 1. the condition of the 40 year old parts was worse than I had imagined and 2. the "new" ride and handling are nothing less than remarkable. In fact a lot of other issues I though I had disappeared.
Downside, regardless of what people tell you, there will be fabrication involved and it would be cheap for parts or labor.
Archer.
70newport (08-22-2015)
Old 08-22-2015 | 06:29 AM
70newport's Avatar
Thanks Archer,
I have replaced everything in the front and rear with the exception of the torsion bars.
Do you by any chance have a picture of your sub frame connectors?
I am very interested to see where your connectors went!
thanks
Gary
Old 08-22-2015 | 06:47 AM
Archer's Avatar
Gary -
Not sure if you can see them in this picture.
But we're talking different cars. Might want to see if any makes usable pieces. If not, then you have to go the fabrication route.
Old 08-22-2015 | 11:53 AM
70newport's Avatar
Thanks again archer.
As far as I can find I will have to make them but that's alright with me. I just need to figure out where I should be mounting them to so I can make them.
Gary
Old 08-22-2015 | 07:54 PM
Archer's Avatar
Gary -
Like I said, it's hard to see on that pic, but the square tubular steel runs from the end of the front frame rails to the beginning of the rear rails. There's a slight bend near the rear of the connectors because we didn't want to cut into the floor pan the way the aftermarket pieces do on this body style.
Find a direct line from the front to rear rails and connect them the best you can.
Old 08-22-2015 | 10:49 PM
70newport's Avatar
Originally Posted by Archer
Gary -
Thanks!
scuba
10-30-2012 05:14 PM
JETBLU
07-12-2012 01:04 AM
Nomadci
08-14-2010 09:49 AM
TwistedWrenches
05-19-2009 04:58 PM
smackhonda
11-23-2008 04:38 PM
