Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   68 newport Sub frame connectors (https://moparforums.com/forums/f11/68-newport-sub-frame-connectors-18842/)
70newport Aug 21, 2015 08:37 AM
Hey guys,
My 68 newport 4 door is really squeeky when driving. I was wondering if you guys think sub frame connectors would help eliminate some of these noises as well as if any of you have built any previously. I can not find any for purchase.
Thanks,
Gary
Archer Aug 21, 2015 09:27 AM
Gary -
Couldn't hurt, but it's probably not your biggest problem. Given the age of your car, the odds are really good, a lot of your suspension is shot - even if it looks OK or even good. Metal fatigues and stretches and rubber bushings rot. Unfortunately, even a good inspection may not reveal the real culprits until you start taking things apart.
I just went through a full suspension overhaul/upgrade (and yes, I added subframe connectors), and 1. the condition of the 40 year old parts was worse than I had imagined and 2. the "new" ride and handling are nothing less than remarkable. In fact a lot of other issues I though I had disappeared.
Downside, regardless of what people tell you, there will be fabrication involved and it would be cheap for parts or labor.
Archer.
70newport Aug 22, 2015 05:29 AM
Thanks Archer,
I have replaced everything in the front and rear with the exception of the torsion bars.
Do you by any chance have a picture of your sub frame connectors?
I am very interested to see where your connectors went!
thanks
Gary
Archer Aug 22, 2015 05:47 AM
Gary -
Not sure if you can see them in this picture.
https://moparforums.com/forums/attac...-rear-mods.jpg
But we're talking different cars. Might want to see if any makes usable pieces. If not, then you have to go the fabrication route.
70newport Aug 22, 2015 10:53 AM
Thanks again archer.
As far as I can find I will have to make them but that's alright with me. I just need to figure out where I should be mounting them to so I can make them.
Gary
Archer Aug 22, 2015 06:54 PM
Gary -
Like I said, it's hard to see on that pic, but the square tubular steel runs from the end of the front frame rails to the beginning of the rear rails. There's a slight bend near the rear of the connectors because we didn't want to cut into the floor pan the way the aftermarket pieces do on this body style.
Find a direct line from the front to rear rails and connect them the best you can.
70newport Aug 22, 2015 09:49 PM
Originally Posted by Archer (Post 130135)
Gary -
Thanks!
