Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   Best Carb Rebuild Kit? (https://moparforums.com/forums/f11/best-carb-rebuild-kit-16813/)
Mr onetwo Feb 22, 2014 05:02 AM
I was hoping for some recommendations on the best quality carburetor rebuild kit for my 1968 383 Newport.It is a Carter AVS #4401s.Thanks.
TVLynn Feb 22, 2014 01:13 PM
That's the best carb ! No special kits. What ever you can find
moe7404 Feb 22, 2014 08:24 PM
i have done lots and lots of them. i have never found a kit that was not up to the job. try setting the float level at 5/16. 7/32 is called out. but check that the fuel doesnt run out the discharge tubes at idle. if it does put it at 7/32. i have never had that happen, but watch for it. the float drop spec really does not matter. as the float hits the bottom of the bowel first. as long as the needle does not jam before you set the lid on. be carefull on the two screws in the middle one at front and one at back if you put the in the wrong place it might strip some threads.
Mr onetwo Feb 23, 2014 08:02 AM
Thanks for the advice guys!I think I'll get this one from Mike's Carb parts...$28.95 http://www.carburetor-parts.com/Cart...968_p_660.html
