Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   Billet alternator pulley (https://moparforums.com/forums/f11/billet-alternator-pulley-19646/)
mizzou580 Aug 24, 2016 07:31 AM
Need advice on installing new billet pulley on alternator without damage. The old pulley came off fine. Some say heat up the pulley, use a press, c clamp. Any thoughts?
Nadir Point Aug 26, 2016 12:27 PM
Assuming there's a nut/washer holding it down, just tighten it up with threadlocker blue and should be good to go.
mizzou580 Aug 26, 2016 03:27 PM
It's press fit.
SPAMBURGER Aug 28, 2016 09:14 AM
On mine the center of the pulley shaft was threaded. I ran a tap through it to clean up the threads and used a couple of different length bolts to pull the pulpy onto the shaft.
RacerHog Aug 28, 2016 10:01 AM
Press it off and then press back on.. If you have trouble, Take it to your local rebuilder... Just my 2 cent... :)
mizzou580 Aug 28, 2016 10:59 AM
I got it on by heating it and a c clamp. Thanks
RacerHog Aug 28, 2016 11:35 AM
Cool... :)
Iowan Aug 28, 2016 01:06 PM
There ya go!:hello:
