Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   disc brake questions (https://moparforums.com/forums/f11/disc-brake-questions-14445/)
dazzlesa Mar 14, 2013 09:51 AM
i have a 66 fury and i installed 73 front dics with minimal problems. i am now trying to install a booster and dual master cylnder. i have the 66 power brake pedal, the 1973 proportioning valve. i bought a new remanufactured 1973 booster and master cyclnder. i cannot get the new booster to fit with the pedal assembly. what do i need? a 66 booster? what do i use as a dual master cylinder?
dazzlesa Mar 14, 2013 10:48 AM
which power booster do you get?
with field installed hydro or without field installed hydro?
jacilynn_s Mar 14, 2013 12:52 PM
did the car originally have manual brakes or power brakes? Reason I ask is it should fit in unless you are using the plate for manual brakes in which case it wont line up.
dazzlesa Mar 15, 2013 10:00 AM
brakes
the car originally had manual brakes. i bought the firewall plate and the brake pedal from a 1966 power brake car
jacilynn_s Mar 15, 2013 02:05 PM
Found these pics on the net
http://www.cbodydrydock.com/forum_vi...c.php?5.133710
reverse of what you are doing but it will show if you have the right parts.
pro-tech Mar 15, 2013 03:32 PM
Great site but who wants to be on dry dock??? Lol
