Gas Cap
I am having trouble finding a gas cap for my monaco, i have tried all the usual suspects, autozone, kragen, pep boys, rock auto.
i now have 5 gas caps that do not fit! haha i have tried purchasing the "wagon" version, and any other part number. i even brought the filler neck into pep boys and test fitted every cap they had on the shelf the tank seems to be original, but none of these fit, it seems like they need to go a bit "deeper" for the thing to lock into place, i do not want to drive the car because gas pours out when taking off from a stop. any ideas? havent found many salvage yards that have old mopars around here, maybe some socal people can point me in a good direction? thanks |
Have you called Year One yet?
Originally Posted by smallxfires
(Post 36796)
i now have 5 gas caps that do not fit! haha i have tried purchasing the "wagon" version, and any other part number. i even brought the filler neck into pep boys and test fitted every cap they had on the shelf the tank seems to be original, but none of these fit, it seems like they need to go a bit "deeper" for the thing to lock into place, i do not want to drive the car because gas pours out when taking off from a stop. any ideas? havent found many salvage yards that have old mopars around here, maybe some socal people can point me in a good direction? thanks I thought the same thing with a cap i had bought @ AZ ... wouldn't turn once all the 'ears' were engaged... Ended up cap fit fine I was just being to gentle... cap is fitting better and better as time goes along, it was just EXTREMELY hard to seat the first few times it was used....Due to new rubber seal, no wear on the 'ears', etc. May try some wd-40 or silicone spray on the rubber. JMO |
| All times are GMT -7. The time now is 10:15 PM. |
