Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   HELP!!! (https://moparforums.com/forums/f11/help-3673/)
Kinger1421 Jul 23, 2009 11:20 AM
HELP!!!
So I have a 65 Dodge 880 Custom with a 6.3l 383! I was driving it in January of this year, left it to sit untill about mid june. Now its not starting at all. I turn the ignition and all i get is a click like the starter is popping but not spinning. So i take the starter to get tested and it passes. Pop and spin! Its got a new Optima Yellow top in it so its getting plenty of power. Also every time i turn the ignition and get the pop i have to pull the neg bat line and put it on to get the same result (just a click). Any suggestions????
Polaradude Jul 23, 2009 11:27 AM
So you are getting the solenoid click and that's it ?
Check the main cable to the starter from the battery.
Check the grounds, battery to block, block to body or whatever your set up may be.
Let us know.
Kinger1421 Jul 23, 2009 12:09 PM
All the connections are good, tight and unblocked. I made sure to check em when i put the starter back on!
Polaradude Jul 23, 2009 01:55 PM
So when you turn the key all you are getting is the solenoid click ?
We need a little more info.
Kinger1421 Jul 23, 2009 02:31 PM
All i get is a click. Then if i try to turn it over again i dont get anything. So i pull the neg bat cable, and reconnect it then when i attempt to start it again i only get another click. I cant seem to get past this effin click.
scotts74birds Jul 23, 2009 03:23 PM
I'm dum but have you tried to turn the engine by hand? When you try to start and hold the key, does the pos bat cable heat-up?
Kinger1421 Jul 23, 2009 03:29 PM
Yes even a lil smoke from the terminal!
scotts74birds Jul 23, 2009 03:56 PM
Try turning the engine by hand.
Kinger1421 Jul 23, 2009 03:59 PM
You mean at the flywheel?
scotts74birds Jul 23, 2009 04:05 PM
probably with a socket and breaker bar at the bolt on the front of the crank. Should be some resistance, but you shouldnt have to reef or stand on it. clockwise while facing the motor.
Kinger1421 Jul 23, 2009 04:11 PM
Sounds pretty effin hazardous but ill give it a shot. lemme know if you come up with anything else. i could use all the brainstorming i can get!
scotts74birds Jul 23, 2009 04:24 PM
Well ya dont do it while its running! but I didnt think that was an issue right now, lol. turn the key off if you are worried about kick-starting.
Kinger1421 Jul 23, 2009 04:37 PM
O running is def a problem so i wouldnt even put the key in it anyway! Soon as i score a Socket that size ima give it a shot
Kinger1421 Jul 23, 2009 06:14 PM
Ok so i replaced the starter relay and its cranking over!!!!!! I havent tried to start it fully because i am noticing a small amount of smoke coming from the neg terminal! What the hell is that about???
scotts74birds Jul 23, 2009 06:31 PM
Neg terminal at the battery? If the connection is tight, one should look at the strands of the cable going into the clamp. It can become corroded and only a few strands may actually be intact, is there alot of green corrosion on the strands? Voltage=pressure. It does not take much to cause resistance in a 12v circuit. So I guess it was the starter relay? Or was it from cleaning the contacts on the wires while changing the relay?
Kinger1421 Jul 23, 2009 06:34 PM
it was the starter relay. now i have a clog somewhere in the fuel line like i did when i first picked this thing up.
scotts74birds Jul 23, 2009 06:43 PM
I am happy for you.
