HELP.. someone pulled my DIST caps off
Old 08-22-2008 | 09:07 PM
Commando's Avatar
I assume that it must be the wires, as the cap only goes on one way.
Old 08-23-2008 | 06:07 AM
ef8340's Avatar
Senior Member
remove no.1 plug and bump the ignition while using your thumb to cover the plug hole when the comp. blows your thumb off the hole that should be where no.1 is on your distributer check on your timing mark on the balancer to see if the line is close to the marks when everything is lined up wire acording to the firing order no. casted onto your intake
98 SNAKE EATER
04-16-2013 04:45 PM
Judgester
10-05-2010 05:42 AM
deadkelly
08-09-2009 08:44 PM
cyclone2321
08-02-2009 08:25 PM
grahamrw2
01-16-2008 03:52 PM
Quick Reply: HELP.. someone pulled my DIST caps off
