Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   My 1964 Chrysler Newport Motor Swap (https://moparforums.com/forums/f11/my-1964-chrysler-newport-motor-swap-20359/)
64 chrstyler Newport May 23, 2017 08:22 AM
I picked up a 1964 Newport Convert. The motor that was in it was completely locked up and junk! So i bought a 1973 or 1974 (not sure) 440 motorhome motor for it. I am going to use the tranny in the car. Just wondering what torque converter I should put on it. Thanks, Joe
Iowan May 23, 2017 08:38 AM
I'd use the one that is in the car. : )
64 chrstyler Newport May 23, 2017 08:47 AM
Will the one that is in the car work with the 440? I am not sure but I think the motor I pulled was a 361.
Iowan May 23, 2017 09:15 AM
Yes :)
Iowan May 23, 2017 09:26 AM
Keep the same converter and put a new seal in the pump in the transmission. The increase in torque from the 440 will have a small effect in stall but should be good to go...:)
TVLynn May 23, 2017 09:10 PM
Going that far I would suggest removing the trans too, give it a good service and re seal it
sometime it can help to turn the trans up on end to reinsert the converter put a small C clamp on the bell housing to keep it in..
