Neutral Switch 68
My neutral switch is no more working, if i ground the wire the car will start.
Unfortunately it is the one prong version (early 68) which is harder to find. Can i use the trhree prong version , using only the pin for the starter relay or is the design (internally) different at all? Thanks, Uwe |
switch
Is this for the 68 Chrysler 300? Is it on the trans or pedal linkage? More info is allways good to help you.
It is for the 1968 Chrysler 300, the switch is in the transmission housing with one prong. The question is, if the easy available switch for the late 68 models and on can be used, even if the backuplight function is not used.
Originally Posted by uwekoch
(Post 64348)
Unfortunately it is the one prong version (early 68) which is harder to find. Can i use the trhree prong version , using only the pin for the starter relay or is the design (internally) different at all? Thanks, Uwe http://cgi.ebay.com/ebaymotors/MOPAR...s#ht_818wt_912 |
Got it, thank's a lot!
(Post 64369)
http://cgi.ebay.com/ebaymotors/MOPAR...Q5fAccessories
In case you wanna save about $20 all in all.. This guy knows his transmission stuff. |
Originally Posted by blue 68 gts
(Post 64373)
Originally Posted by rexus31
(Post 64379)
True, they do know their stuff and I have bought from them before however, his are used. I'd rather pay a little extra and get a new one.
He built my trans, and I'd feel 100% safe running anything new or used from him. |
(Post 64382)
Yes, but most of these parts he has had for decades. You should see Pats garages.. FILLED with Torqueflites.
ESPECIALLY electrical stuff...
G'Day,
I saw a question about your plastic side moulding clips... Iso I joined up to give you this website. http://www.restorationspecialties.com This is where I have located all the different clips for your 300 |
| All times are GMT -7. The time now is 04:33 AM. |
