Mopar Forums (/forums/)
-   C-Body (https://moparforums.com/forums/f11/)
-   -   New to cars help (https://moparforums.com/forums/f11/new-cars-help-19002/)
keaton57 Oct 31, 2015 12:26 PM
New to cars help
Hi, I am 17 and just got a 1966 chrylser new port and started working on it. We can't seem to get fuel to the motor. we replaced fuel pump and checked the fuel lines and they were good but when we blew air into the gas tank we couldn't get it to come out either side. any suggestions on fixing this or does anyone know how the gas line goes in the gas tank? I don't want to replace the entire gas tank so if there is any suggestions I would appreciate it. thanks
Drag Pak Oct 31, 2015 03:45 PM
1 Attachment(s)
If it is a big block, check the fuel pump pushrod. It is a wear item.
keaton57 Oct 31, 2015 04:04 PM
when we changed the fuel pump we checked the pushrod and it was fine I believe
Coronet 500 Nov 1, 2015 04:47 AM
If you drop tank and remove the fuel sender/pickup you'll find a filter "sock" that probably deteriorated and plugging fuel line tube.
keaton57 Nov 1, 2015 05:26 AM
thanks
alright thank you I will do try that next
Iowan Nov 1, 2015 07:02 AM
If the car has been sitting for some time, dropping the tank and giving it a good clean out along with replacing all the hoses and the filter would be a good idea.
Coronet 500 Nov 1, 2015 07:40 AM
If the engine has not been started or this just happened I would take a gas can and hose to the fuel pump and start it. If it runs then you have your answer and dropping the tank is warranted.
Being an old car, inspecting, repairing and possibly upgrading the whole fuel system is always a good idea. If it's not failing now it will.
DDodger Nov 1, 2015 09:23 AM
This sure sounds like a tank / pickup or supply line problem
Go over to MyMopar and download a factory shop manual, free:
And no, LOL, I don't work there.
If you read through the fuel section, there are checks you can make on the pump to determine if it's OK, EG, buy a vacuum / pressure gauge at the parts store, which don't cost that much. The pump should be able (generally) to pull at least 10-12" vacuum Hg.
Not being able to blow air back into the tank sound like that is the trouble area.
