Turn Signal Switch - 68 Plymouth Fury
Anyone know where to find a turn signal switch for a 68 Fury III? Everything I'm seeing is NOS going for $150+
That seems pretty spendy to get my blinkers working again. |
Switch
Originally Posted by jstaples2
(Post 130946)
There used to be places that offered just the plastic cam ??? If the wiring is ok ???
Pulled the steering wheel off and found the arm on the plastic cam was broken off in there. That's why the signal arm won't cancel after completing the turn. The wiring all is ok. I'll look around to see if I can just get a plastic cam.
If all else fails I'll see if I can work up a bracket or something to re-attach the broken piece. |
This may work http://www.ebay.com/itm/Mopar-67-68-...gcqQ-A&vxp=mtr
| All times are GMT -7. The time now is 01:04 AM. |
