Upper Ball Joints '68 Town and Country
1 Attachment(s)
I'm having trouble locating upper ball joints for Le Barge. Any suggestions? Thanks, Ed
'68 Chrysler Town & Country Sovereign Gold 383 2bbl. |
Mid Canada Suspension.
I don't know where you are , just a quick look. AutoZone has them, I would look for Moog ? brand though...
It does require a special socket for replacement.. |
Drat! I need the lowers as well. They're harder to find it appears.
Originally Posted by EdR
(Post 77029)
(Post 77029)
Lower Ball Joints
1 Attachment(s)
Thanks, I'll call them tomorrow.
Ball Joints
Hi Ed sent you a PM on the ball joints
Nice wagon Ed,
Originally Posted by TVLynn
(Post 76871)
Originally Posted by bboogieart
(Post 77455)
Nice wagon Ed,
Let me know if you find this tool or if anyone knows where to find them. I have had no luck. They are specific to the c-bodies, and from what I read some 70's light trucks. Every time I think i've found one it turns out to be the wrong size. |
Ball Joints
I do believe the lowers are the whole assembly I believe
Originally Posted by shovel55
(Post 77477)
bremereric
Thanx I will have to measue to make sure. I do believe that the a and b bodies have different sizes as well but could be wrong. I will see what mancini has. Did you use yours for a c body? They are specific, as I mentioned. shovel55 Yes the lowers are a complete cast iron unit that bolts to the spindle through the backing with the two lower bolts, and also connects to the tie rod end. Going to have to unload the torsion bar or put the jack under the spindle so it does not come flying apart, when un bolted. Lot's of tension and potential for injury. Be careful. |
1 Attachment(s)
herer is a picture of the lower ball joint hanging down underneith the spindle. You won't need to remove the backing plate, I just did cause I was cleaning and painting. You can see how the lower joint will attach. Taking this apart can be dangerous but common sence and a little for thought will go a long way. I had the car supported by the frame and used the jack to lift the lower control arm and take the tension off it.
Ball Joints
I do have the two lower ones if anyone is looking for a set.They are Moog K7003 and K7005 new in the box.These are a special order nowadays.
(Post 77555)
bremereric
Thanx I will have to measue to make sure. I do believe that the a and b bodies have different sizes as well but could be wrong. I will see what mancini has. Did you use yours for a c body? They are specific, as I mentioned. shovel55 Yes the lowers are a complete cast iron unit that bolts to the spindle through the backing with the two lower bolts, and also connects to the tie rod end. Going to have to unload the torsion bar or put the jack under the spindle so it does not come flying apart, when un bolted. Lot's of tension and potential for injury. Be careful. http://chucker54.stores.yahoo.net/frsuto.html |
Thanx for the link. I do beleive mine are 1.951 but have not checked them yet. I have a cheap mike but am not familiar with converting inches to what ever that 1.951 is.
| All times are GMT -7. The time now is 04:13 AM. |
