340 thermaquad ???
Old Apr 22, 2010 | 03:26 PM
mr.magoo's Avatar
Question 340 thermaquad ???
does anybody know how many cfms is the original thermaquad that went into a 72 340 wedge challenger?????
Old Apr 22, 2010 | 04:35 PM
1966sportfury's Avatar
A.K.A Bob Dodge
the only cfms i know of thermal quads were 700,800,900, they are vaccum controled so it think 700 would be the carb? they may have 750 850? im not positive but i think the 700 was the smallest.
Old Apr 22, 2010 | 06:22 PM
mr.magoo's Avatar
thanks sportfury i found on allpar it says it was a 850 cfm carb but i dont know if i can belive that knowing that compression ratios in 72 went from 10 to 8, you would thing the carb would too...i runnig 600 cfm now but i think ill go to 700...850 will be to much i think..
Old Apr 23, 2010 | 07:05 AM
Archer's Avatar
magoo -
I ran a Thermoquad on my old 318/340 (318 block/340 hi-perf heads, etc) before I swapped in the 440. IIRC, '66 is correct, they were about 800 cfm.
Old Apr 23, 2010 | 02:05 PM
mr.magoo's Avatar
thanks archer i actually have the original thermaquad and i found a guy to restore it to new so b4 i spend the money on a new one im try the old one
Old Apr 23, 2010 | 07:45 PM
Archer's Avatar
magoo -
I have a hunch you'll like it.
When/if you go to an aftermarket manifold, remember the size of the secondaries and either get the right manifold or a spacer to go from the spread bore to square. I'm not saying I forgot to do that ... once ...
Old Apr 24, 2010 | 03:55 AM
Sangetsu's Avatar
Hopefully your guy knows what he's doing. But the Thermoquad is an easy carb to work on, and the car will run strong with it.
Old Jan 6, 2011 | 10:28 PM
gccruzer's Avatar
Check out thermoquads.com...he's got all kinds of good info on just about every TQ made, including CFM info...
