Mopar Forums (/forums/)
-   E-Body (https://moparforums.com/forums/f12/)
-   -   340 thermaquad ??? (https://moparforums.com/forums/f12/340-thermaquad-5991/)
mr.magoo Apr 22, 2010 03:26 PM
340 thermaquad ???
does anybody know how many cfms is the original thermaquad that went into a 72 340 wedge challenger?????:confused:
1966sportfury Apr 22, 2010 04:35 PM
the only cfms i know of thermal quads were 700,800,900, they are vaccum controled so it think 700 would be the carb? they may have 750 850? im not positive but i think the 700 was the smallest.
mr.magoo Apr 22, 2010 06:22 PM
thanks sportfury i found on allpar it says it was a 850 cfm carb but i dont know if i can belive that knowing that compression ratios in 72 went from 10 to 8, you would thing the carb would too...i runnig 600 cfm now but i think ill go to 700...850 will be to much i think..:D
Archer Apr 23, 2010 07:05 AM
magoo -
I ran a Thermoquad on my old 318/340 (318 block/340 hi-perf heads, etc) before I swapped in the 440. IIRC, '66 is correct, they were about 800 cfm.
mr.magoo Apr 23, 2010 02:05 PM
thanks archer i actually have the original thermaquad and i found a guy to restore it to new so b4 i spend the money on a new one im try the old one ;)
Archer Apr 23, 2010 07:45 PM
magoo -
I have a hunch you'll like it.
When/if you go to an aftermarket manifold, remember the size of the secondaries and either get the right manifold or a spacer to go from the spread bore to square. I'm not saying I forgot to do that ... once ...
Sangetsu Apr 24, 2010 03:55 AM
Hopefully your guy knows what he's doing. But the Thermoquad is an easy carb to work on, and the car will run strong with it.
gccruzer Jan 6, 2011 10:28 PM
Check out thermoquads.com...he's got all kinds of good info on just about every TQ made, including CFM info...
