70 Grille
Will a 70 grille fit a 74????? or is there a swap kit out there i looooovvveee the 70 grille
My guess is as far as a bolt in NO the body was changed between 70 and 71, But with enough talent in body work I suppose anything is possible. Look at George baris's creations.
I am assuming a cuda vs challenger It is pretty simple The 70s had a one year header that is different It surronds the grill. Swap the header and the grill together.
4 Attachment(s)
It should, The fenders are the same as the 70, but you need everything because the bumper is different, so is the vanlance. The marker light is different too. It just depends how much of the grill you have.
