73 Cuda Dash Replacement
I need to replace the dash pad in my 73 Cuda. Does anyone have an exploded diagram or set-by-step instructions for this procedure? Thx
no, but I just did mine, put a dash cap on, and it wasnt that bad, I would say the hardest part is the wireing, getting it back correct I would mark all wires that arent obvious, anyway its only 5 or 6 bolts/screws 4 from the defrost vents inside top by the windshield and 2 bolts 1 by each kick panel on the sides also found a brace about dead center behind the ash tray and I still cant find where to bolt it to now :)
hope it helps, just dive in its not as bad as you have herd. |
It helps to have a friend with you, it can be a handfull trying to lift it out alone. :)
Originally Posted by 3404speedcuda
(Post 70584)
