Brake Question
Brake Question
!971 Cuda stock Disc/drum, rebuilt original calipers. When take the car out cold, brakes are fine. After a bit of cruising, back home now, front brakes lock up(feels like E-brake is on, but isn't). Rears are okay(free wheeling).
What's going on? Where do I start. The master has been replaced also. Driving season is upon us, would like to sort this out. Help! Thank you!
Sorry for my first post being a problem.
Do the easy stuff first. Make sure the wheel cylinders or the calibers aren't locking up with heat.
When the breaks start acting up, get home, pop the wheel and have someone pump the pedal.
See what the cylinder does.
Did you mix up the ft and rear on the master.
Was back at it today. Jacked car up cold, wheel spun freely. Started car let run few minutes, wheel spins freely. Pumped brakes couple of times, fronts lock up tight. Turn car off and loosen masters four bolts, and brakes release. Is it a faulty master, or rod adjustment? Or something else? Master part number is Napa P2066.
Master was replaced 2 years ago, never had problem before? WTH thanks!
rachel4291
11-01-2019 02:23 PM
motorcitymopar586
09-28-2013 12:12 PM
