need help converting clutch pedal assy
Does anyone know how difficult it is to remove a clutch/brake pedal assy to just a brake pedal. Looking at a 73 cuda on ebay that has an automatic trans but still has the clutch/brake pedal installed.
Clutch pedal
I think you could remove the tube and brakets holding the pedals and get rid of the clutch, add a spacer and retain the brake pedal.
I suspect going to a wrecking, looking at a auto trans installation and acquiring whats needed or the entire assembly. |
