torque converters?
Old Nov 9, 2008 | 07:59 PM
Commando's Avatar
Are you pulling the engine out, if so you need to be able to pull it off of the transmission. You start with taking the inspection plate off the tans, it is a small metal piece that sits just below the engine on the trans. Next you will be able to see where the flex plate and torques converter meet up, there should be four bolts there which require the engine to be turned after each one is removed. That is pretty much it, let me know if you have any questions.
bill55az
Dec 29, 2011 06:48 PM
vegas1956
Nov 20, 2011 08:37 AM
Drakovich
Jul 11, 2011 02:57 PM
unit_121
Dec 1, 2008 07:46 PM
got2mopars
Sep 22, 2007 05:44 PM
