Unisteer rack & pinion
Have anybody installed a rack & pinion steering from Unisteer ? and have trouble with the 90 degree conection between steeringshaft and the rack from unisteer , there are used 2 universal joints , they have too take 45 degree each , and you not get any smooth steering feeling , anybody have an idea what too do for too get this right ? , unisteer dont know and say this will work , but it does NOT.
Thanks Lars |
I don't have experience with this one but I have with others. The steering shaft has to be fazed like a drive shaft, if you have even one joint off you will feel it.......
Photo might help us address the problem.... :)
Also what are you trying to install it in? |
Originally Posted by hemiaction
(Post 144957)
Thanks Lars |
Jim121
Did you get your steering shaft problems worked out?? How do you rate the Unisteer Rack and Pinion steering set up now that you have used it for a while?? I’m seriously considering converting my 70 Challenger steering to the Unisteer system. In order to have better room in the engine bay as well have better steering and less weight. I would appreciate your input please.
Originally Posted by Jim121
(Post 153348)
unisteer , and follow their instruction and mounting i think you will be disapointed , we have 2 Challengers here With the unisteer setup and that is not recomended , not at all. Thanks Lars |
Unisteer
Did you get my Reply from this AM?????
| All times are GMT -7. The time now is 08:30 AM. |
