Mopar Forums (/forums/)
-   E-Body (https://moparforums.com/forums/f12/)
-   -   Will 1970 quarters fit on a 1973 (https://moparforums.com/forums/f12/will-1970-quarters-fit-1973-a-24394/)
DLinson Jan 11, 2022 03:00 PM
I'm restoring a 73 Barracuda for my sister and it needs quarters. The body shop that put on the skins for my Uncle when he owned it distroyed them. I had the car stripped and found 1/2 inch of bondo over the seams, unground welds, the definition of cave and pave.
I'd like to put 70 quarters on the 73. We are filling in the marker lights front and rear. The 70 rear quarter marker lights are well below the body line compared to the 73 which are on the body line.
Will the quarter fit the tail light panel? Door opening? Sail panel.
I've read that AMD is preferred over Goodmark, do you all agree?
Thanks for any help
Iowan Jan 11, 2022 05:42 PM
I believe that you can...
Lostviking Jan 12, 2022 02:18 PM
No. 70-71 and then 72-74.
Iowan Jan 12, 2022 05:31 PM
What is the difference between the two besides side markers that he's filling.
DLinson Jan 13, 2022 06:01 AM
It looks like the trunk lid, trunk gutters, roof, and door skins are all the same 70-74. The tail panels are different but is the interface between the tail panel to the quarter different?
Lostviking Jan 15, 2022 01:09 PM
AMD sells them. They list the two as different, so you need to ask them if the mounting points match. If the only difference is the marker lights that can be fixed, or ignored.
Sangetsu Oct 15, 2022 12:48 AM
They fit. The only difference is in the marker lights. The ‘72 and later used recessed marker lights.
