Mopar Forums (/forums/)
-   F-Body (https://moparforums.com/forums/f13/)
-   -   Coolant leak Help (https://moparforums.com/forums/f13/coolant-leak-help-10088/)
77Aspen Jul 10, 2011 04:43 PM
Coolant leak Help
1 Attachment(s)
Hi Everyone,
Just bout a 77' aspen wagon with a super slant6 225. Today when I got home I noticed some coolant leaking front the front of the engine, that part the fan is connected to. I started the car up to see exactly where the coolant was coming from and it started to pour fairly quickly from the area I have circled in the picture.
Any clue as to what is wrong and what needs to be done. I am a complete novice and slowly learning about mechanics.
Thanks,
Wes
Attachment 15933
440roadrunner Jul 10, 2011 05:21 PM
Looks to me like the water pump is bad
77Aspen Jul 10, 2011 05:48 PM
Ok so the water pump is what the fan is connected to? Could it be the gasket? Thanks
Coronet 500 Jul 10, 2011 06:05 PM
Pumps have a hole under there to where the shaft is. It is an indicator to tell us that the pump seal is leaking.
77Aspen Jul 10, 2011 06:51 PM
ohh ok, so does that mean the whole pump needs replacing or just the seal?
mr340 Jul 10, 2011 07:12 PM
replace the pump.
fivepoint Jul 10, 2011 07:17 PM
Replace the pump. Its a fairly simple job. Go to your local parts store to get a pump. The pump will come with a mounting gasket. It will require the basic tools. If your new to this and want to learn, a manual would be a wise investment.
Your going to drain the coolant to change the pump. It would be a good time to inspect the hoses and change the bad ones. If your coolant looks rusty or murky, put new coolant in too.
TVLynn Jul 10, 2011 08:48 PM
If you plan on driving it Replace the leaky water pump, both radiator hoses, the by pass hose, the thermostat and the belts. Then you wont have to worry for a long long time.. I could probably do it in a hour or so. Make an afternoon project our of it..
It is easier to cut the hoses rather than wiggle them off the radiator -possibly damage the radiator
bremereric Jul 10, 2011 10:09 PM
Wes that's the weep hole for the water pump seal...its a tell tale for the front seal failure...if you replace the pump it is also your chance to replace the other things you take off if they are in sad shape....:look:
77Aspen Jul 11, 2011 03:34 AM
1 Attachment(s)
Wow guys thanks a lot for the quick and informative replies. I looked on ebay and it looks like it is a bolt on part with one gasket so it doesnt appear to be overly difficult. I will replace the hoses as suggested to. Again, thanks for the help.
Wes
Here she is... immaculate - 1 owner, 58,000 mil
es, garage kept.
Attachment 15929
440roadrunner Jul 11, 2011 07:46 AM
http://i54.tinypic.com/2cne440.jpg
is the understatement of the year. I don't know where all you can buy these, but reprints and CD's show up on ebay all the time.
Get a copy of the FACTORY shop manual, not a Chilton or a Haynes
Prob'ly cost you 20-40 bucks
bremereric Jul 11, 2011 02:17 PM
1 Attachment(s)
Mine cost 9.95 plus 4 bucks shipping off of eggbay...got real lucky...: hail :
Attachment 15926
