Exhaust Setup
Old Apr 23, 2012 | 03:58 PM
1978VolareRR318's Avatar
Exhaust Setup
So my question is for these guys since you can't run a good exhaust setup straight back cause everything is offset is; what is the best way to maybe do a 2'5 inch exhaust with a 3' tip on these vehicles. Do you have to do a custom setup or can you use a AAR Cuda or T/A Challenger exhaust and just bolt that up? Any help would be appreciated.
Old Apr 23, 2012 | 08:26 PM
Archer's Avatar
78-
I'd just find a good muffler shop that knows how to bend pipe and get a custom job done. Mine cost about $500 with and X pipe and it fit and works perfectly.
Old Apr 23, 2012 | 10:06 PM
If you have a hump in your tank and it is offset to one side have them run it to the rear tires and then dump it out the sides. Mine is a H-pipe that dumps out in front of the rear tires. Not exactly legal in all states.
Old Apr 24, 2012 | 02:35 AM
I had the TA style side exit mufflers on a 77 RR was a custom install
Old Apr 24, 2012 | 10:50 AM
Thanks for the responses the car does have the offset gas tank so I think I will just run the exhaust out in front of rear tires.
unruler
Mar 26, 2009 05:30 AM
gilligan
Mar 18, 2009 04:52 AM
Crazy4Carz.Com
Feb 3, 2009 10:43 PM
GTXpress
Nov 25, 2008 10:30 PM
Whiskey
Sep 11, 2008 06:25 AM
