need help with my 76 aspen
Old 05-09-2013 | 07:13 PM
nick1976aspen's Avatar
hi I just bought a 1976 aspen 4 door with a slant6 and a 904 trans trying to make it in to a little firday night sleeper I allredy bought a bandm ratchet pro shifter but seeing if u guys have any suggestions
Old 05-09-2013 | 08:24 PM
moe7404's Avatar
if its strictly sat night specl go to a 8 3/4 rear or a 8 1/4 rear. do NOT EVER EVER EVER use a 7 1/4 rear for anything, EVER. you might try a 4.56 ratio. this is THE best place for / 6 info. http://www.slantsix.org/
Old 05-10-2013 | 06:16 AM
put a 3.23 or 3.55 rear end You should be able to find a 8 1/4 rear for your Aspen/Volare.
A "B" body 8 3/4 is a close fit. just have to push the springs apart 1/4"-1/2" use the 8 3/4 shock plates & new U bolts. - This eliminates the rubber spring mounting. Had an 8 3/4 in a Volare RR
Old 06-23-2013 | 07:08 PM
440 aspen's Avatar
What kind of budget are you on?
dodgeaspenrookie
07-23-2012 01:15 PM
bremereric
03-03-2011 11:02 AM
09-09-2010 03:51 PM
MIPLAYSTATION
11-24-2009 04:16 PM
richinny
07-01-2008 04:46 PM
