Mopar Forums (/forums/)
-   Classic Trucks (pre-1972) (https://moparforums.com/forums/f15/)
-   -   360 build (https://moparforums.com/forums/f15/360-build-11518/)
85dodgeram350 Jan 23, 2012 04:22 PM
360 build
hey i am looking to get a cam for my 360 but i want to keep the stock converter to keep the good rpms from the overdrive tranny i want to know a good cam size i can use with the stock stall the truck has 410 rear end gears and a dana 60 and i want it to sound choppy and lopy but not overkill for street use any suggestion will help thanks
bremereric Jan 23, 2012 05:12 PM
Call Comp Cams and ask them about their Thumper and Mutha Thumper cams.
http://www.compcams.com/DefaultWide.aspx
http://www.youtube.com/watch?v=ZNe9i...layer_embedded
78doubleR Jan 23, 2012 05:34 PM
something around .450"-.499" range for lift. 260-270 duration.
Coronet 500 Jan 23, 2012 05:54 PM
Just for fun I ran your truck, stock everything with the XE256H on the Camquest 6. It came up 233hp 340tq. Putting small tube headers on changed it to 264hp 374tq. None of the other cams, even if bigger, showed any gains showing that manifold, heads and exhaust are the restricting factors. Look at the whole package when deciding and don't overlook the stock 340 HP cams.
85dodgeram350 Jan 25, 2012 06:58 AM
Thank you for the suggestion more with be helpful any expirence running the cams will be great
