69 dodge pickup headers
Hi guys, I have a 69 Dodge pickup with a 383 and was wondering if anyone knew where I could get some headers for it. Would some for a A, B, C body etc... fit on it? I looked everywhere for some for a pickup but cant find anything. THANKS
I have owned a 71 and 77 .. but not a pre-70. But I have heard that a B body header can be made to fit.
is it a D-series (2wd) or W-series(4wd)?
This link here is for the W-series.
http://store.summitracing.com/egnsea...115+4294908081 Let me know if they don't work. |
Its a 2wd, thanks I was unsure the difference in the w100 and d100. That is a big price difference in the two. Would the 4wd headers fit on my 2wd? That would save me about $300.
I'm not sure if they will. The only reason why they wouldn't would be because of the crossmember under the motor in the d-series. I believe that the w-series doesn't have it there.
Originally Posted by 15austin
(Post 5543)
http://www.sweptline.com/tech/engine3.html |
Thanks for the info stickshifted, I still need a set. Ill check out that site.
It doesnt matter if Summit says it will fit get ready to cut the frame heat and bend the headers an maybe, just maybe it will fit. they will also most likely send you the wrong header bolts get ready to improvise
