1929 CRYSLER MODEL 65.
To fellow above model owners.There's a modern oil seal conversion for MOPAR part numbers: 79448/891434,
Dodge 6cyl models DA.There's a modern neoprene rubber double lipped spring loaded oil seal, That replaces the leather insert, Dimensions are: 50 mm ID X 67MM ODX 13MM W., These fit straight into the metal retainer plate where the leather insert goes into, NO modification's required. |
| All times are GMT -7. The time now is 02:29 AM. |
