1938 Chrysler C18 rear axle outer bearing lube
Old Jul 2, 2024 | 02:11 AM
Royal38's Avatar
Hi from Norway,
From my manual, these bearings shall be re-lubed at 12000 miles via plugs located in the aft end of the casting - item 32, lube point #24/25 on attached drwg.
However, no quantity is mentioned - can anyone enlighten me, please?
Ole
File Type: pdf
Old Jul 2, 2024 | 05:15 AM
Kuvasz101's Avatar
I don't think you could over-lube the bearings. When assembling rear diffs we would pack the axle bearings. I'd say a good 3-5 pumps should certainly be adequate. When I say pump
I'm referring to pumps of the handle on a mechanical grease gun.
Old Jul 2, 2024 | 02:02 PM
Royal38's Avatar
Talking 1938 Chrysler C18 rear axle outer bearing lube
Hi Kuvasz101,
Thanks a million for your fast and great reply!
Best regards,
Ole
Old Jul 2, 2024 | 05:37 PM
Kuvasz101's Avatar
What a beautiful car!!
Cuda Man
Aug 22, 2021 05:46 AM
wma1950
Jan 14, 2014 07:40 PM
70newport
Jun 5, 2013 06:23 PM
mychrysler
Nov 11, 2012 02:26 AM
smallxfires
Jan 29, 2010 10:18 AM
