1950 Chrysler Windsor engine pull
Is it better to pull the engine alone, or the entire engine/transmission as a unit?
Thanks, DLD |
Originally Posted by DLD
(Post 135788)
Thanks, DLD or are you lazy, I'm LAZY and would try it. |
As far as I know the trans does not need to come out. The engine is stuck and won't turn over. It's been sitting for many years. I'm willing to risk it not needing to come out, I just wasn't sure if there was a reason NOT to pull the engine alone.
NOPE!
Turns out the transmission has to come off, the engine and bell housing come out together. Wasn't too bad. Turns out it spun the #6 rod bearing. Crank has been turned .010 under, and the rod re-sized. Still need to bore the block for new pistons, and I'm working on getting the water tube out, it's being a bugger! Replaced all the exhaust valve guides, the intake guides were in remarkably good shape, well within tolerances.
I got the water distribution tube out today! All in one piece! It only took about three months of tinkering, sprayingPB Blaster in it and driving a piece of 1/8 x 1 steel into it and pulling it out repeatedly! I was shocked it came out in one piece, saves me a lot of trouble. If I had any way of telling the condition before pulling it I could have left it in.
Cool.... Thanks for the Up Date.. Hope its coming along nicely?
Slowly.....hoping to pick up a little momentum now that the tube is out.
(Post 140295)
I need to figure out how to post photos. :-/
Thanks, I'll give it a try!
1 Attachment(s)
Let's see if this worked:
OK, so now I've got it!
1 Attachment(s)
Here's the water distribution tube, fortunately it came out in one piece!
Good Job.... Nice looking ride... :) :)
Nice car, put a late Hemi in it!
(Post 140343)
I highly recommend you go to this very active, vintage mopar site. Its an excellent source of help.
http://p15-d24.com/forum/4-p15-d24-forum/
(Post 135788)
Thanks, DLD |
Good answer because if I owned it the body would not mach the motor transmission, rear axle, front suspension under it!!!!!!!!:)
cash |
Late gene 3 hemi........go for it....:)
| All times are GMT -7. The time now is 08:05 AM. |
