49 coronet runs good but won't start without starter fluid
Old 11-13-2017, 12:33 PM
smitty49coronet's Avatar
Just bought my 49 Coronet and it seems to run pretty good but it will not start without starter fluid. Once I spray a little In the carb it starts right up. Any idea of what that could be? Thanks!
Old 11-13-2017, 12:54 PM
Archer's Avatar
smitty -
Choke? Is there one and does it work?
Old 11-14-2017, 05:21 AM
Originally Posted by Archer
smitty -
it has an automatic choke. It seem to work fine. I messed with it while it runs and it ramps the engine up then when I push the throttle it brings the idle back down.
Old 11-14-2017, 06:09 AM
Archer's Avatar
smitty -
Does it close all the way when cold?
How are you trying to "start" the engine without the starter fluid?
Typical on a cold engine would be down three times on the accelerator pedal, turn the key while holding the pedal 1/2 way.with occasional pumps as needed.
Old 11-14-2017, 09:30 AM
It does close all the way when cold.
I have fried the 3 pump and throttle half way down method, still no good.
It does this even after I drive it for a while. Once I shut it off, it will not start again without starter fluid.
could a weak coil cause this at all?
Old 11-14-2017, 09:49 AM
Archer's Avatar
smitty -
Unfortunately, it's going to be trail and error.
Re: the carb, when you manually move the throttle, does fuel squirt into the venturies?
What happens if you dribble gas into the carb instead of starter fluid?
And yeah, how old is the gas?
Arfcher
Old 11-15-2017, 09:46 AM
Sorry, been really busy at work. I'm going to look at it tonight and I'll let you know. Thanks for your help so far.
Old 11-15-2017, 09:47 AM
Also gas looks good and doesn't smell bad. I just changed the inline fuel filter and wasn't horrible.
Old 11-15-2017, 08:15 PM
So I got home from work and decided to pull the carb and took it all apart. Turns out the the cold start primer was clogged. Cold start prime was clogged
Old 11-15-2017, 08:36 PM
Got another quick question. Can I get rid of the oil bath air cleaner and put on a regular air cleaner?
PlymouthPatrick
07-10-2016 06:40 AM
mcarroll
08-25-2015 02:38 PM
xvc
05-01-2011 10:26 AM
blazer
07-03-2010 04:07 PM
Quick Reply: 49 coronet runs good but won't start without starter fluid
